Rudedog614
Jul 01, 2017Guide
LB2120 can't send SMS and disconnects
I just installed an LB2120 and activated a new SIM on Verizon for it.
The data connection seems to work well, but I cannot send or receive SMS (text) messages.
When I try to send a text message, I get the error "Message Failed to Send" in a pink message box.
Then the screen goes gray and displays "Lost connection to device. Your device may be restarting or powered off." The LEDs on the unit do not change, so I don't think it is actually restarting.
If I wait a long time, a pop-up dialgo appears saying "Message Failed to Send" with "Try Again" and "Cancel Draft" buttons.
I would like to setup the LB2120 to send alerts, but I figured that the Messaging should work and be tested first.
Also, can anyone explain what the Advanced setting "Enable Diagnostics" actually does? If it creates a log I would love to see it.
Thanks for any help or advice
- DarrenMSr. NETGEAR Moderator
Hello Rudedog614
Have you checked with verizon to see if that Sim card has a limitation on texts and is just a data card?
DarrenM
Hi Darren,
I have checked and that may have been the issue. The Verizon tech reset or reenabled the SMS feature, but I have not gotten back to the LB2120 yet to test it. I will do that soon.
BUT, if that is the issue, the router does not handle that condition gracefully. Imo, it should provide a more useful error message and not go into the long disconnect cycle. Maybe this can be looked at for a future firmware rev.
Also, are you able to explain to me what enabling diagnostics actually does and if there is any way mere mortals can see the diagnostic details?
Thanks for the reply!
I am back to my LB2120, and whatever Verizon did does not seem to have changed anything.
How can I get more details about how the messaging is failing?
Thanks
- steveswNETGEAR Expert
Verizon requires an IMS bearer to be setup in order to send SMS.
The LB1120 does not support this and therefore SMS will not work on Verizon.
- msausenTutor
I think the bigger issue is the LB reboots when it fails. Could we get that fixed at least?
