agdodge4x4's avatar
agdodge4x4
Luminary
Jan 27, 2018
Lb2120 firmware update failure
It won't update. Reset it a bunch. Rebooted. Doesn't work. How do you get this thing to update?
Testing this device since my mr1100 has been an absolute nightmare hell. Any easy fix?
  • Solved.  You have to be in BRIDGE MODE to update this router.
    This kind of thing needs to be in the manual, guys.  You can't expect everyone to figure this out for themselves. :smileymad:
    • navlrac's avatar
      navlrac
      Guide
      Not true.
      I've succesfully updated my two LB2120's, one each over LTE and WAN connections, in router mode. It did require a fast and stable LTE connection. Any WAN connection with packet loss will cause firmware download failures (requires a device reboot to recover from).
      Note, also, the web UI does not allow firmware update without a SIM inserted. I was able to bypass that by modifying the page in Chrome.
      • agdodge4x4's avatar
        agdodge4x4
        Luminary
        Not sure what to tell you.  Your procedure didn't work at all.  What it sounds like is a piss poor implementation of hardware and software.  That's not meant as an insult to you.  I've had WAY more than a few netgear devices that just don't work the way some others expect them too.  Just the way the devices behave.  It's par for the course.
        I have a screaming fast connection that is stable.  No go.  Literally NO CHANGE TO CONFIGURATION aside from clikcing 'bridge mode' allowed the update to succeed unhindered.  I tried the other way for 2 days just out of curiosity.  It didn't work.
        This is a guinea pig device.  It's not anywhere close to the speed of the MR1100 though.  I had such trouble with the other one, I just got a few devices to test out.  I'll return everything except the most stable and quick.
  • It doesnt want to update the firmware neither in Bridge nor router mode   there is a BUG in the firmware upgrade package  it gets to 52% or 54% and it freezes there  PLEASE FIX!!!
    • navlrac's avatar
      navlrac
      Guide
      Seems Netgear have really stuffed this model. While I managed to update over the WAN port on a fast 100mbit link, and once over LTE (after about 20 attempts with reboot each time) it seems many people havn't been able to.
      Much worse issue is that they offer no way to download the firmware to a PC and update via the web interface, so even if a new firmware is provided, many people will have no way to apply it.
    • JasonN's avatar
      JasonN
      NETGEAR Employee Retired
      Hi Everyone,
      Does anyone still have the issue of updating the firmware? Please PM me and I will work with you. Thank you. :]
      - Jason N
      • Brookeville's avatar
        Brookeville
        Jason;
        I am ready to purchase a Netgear LB-1120.  My application will require proper functionality of the bridge mode feature.  I have been following the realted blog/support/Netgear forum threads for several weeks.  There have obviously been some firmware upgrades that correct the problems of bridge mode operation which was evidently problematic in the earlier versions of the LB-1120 shipments.  TWO related questions;
        1.What is the current version of firmware that is shipping with the LB-1120?
        2.Is that version available on new shipments as of a particular date i.e.,  October ##, 2017? or some other date  and how do I I.D. the proper serial sequence, etc?.  BOTTOM LINE:  If possible I would like to avoid having to perform a software update on a new unit if polssible!  Please advise.  THANKS, Stan
