Azerty32's avatar
Azerty32
Initiate
Aug 04, 2021
[LB2120] How to enter MCC and MNC for APN configuration?
Hello,
I have a LB2120 4G router and I have some difficulties to configure the APN - usage in France. My mobile provider is a MVNO called Symamobile. I am supposed to enter a MCC and MNC to configure the APN. This is what I did on my mobile phone and it works. However, I see no possibility to enter MCC MNC on LB2120 APN settings page. Only APN=symamobile.com is not sufficient. The power led remains orange and the home page of LB2120 says that 3G/4G is disconnected, that I should enter an APN.
Is there any workaround or should I conclude that it will be impossible to configure it?
Thank you in advance for your help!
  • michaelkenward's avatar
    michaelkenward
    Azerty32 wrote:
    Hello,
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your LB2120 hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • Azerty32's avatar
      Azerty32
      Initiate
      michaelkenward wrote:
      Azerty32 wrote:
      Hello,
      Support | NETGEAR
      Hello,
      Thank you for the tips.
      I already checked the manual and could not find the solution. I hope someone could help me otherwise I will choose another device (or mobile provider).
