Toshia_Renee's avatar
Toshia_Renee
Follower
Mar 13, 2021
LM1200 green light no internet
I have my LM1200 connected to a tp-link wireless router and I had internet for maybe 2 hours then it said no internet but my devices are connected. My modem and routers lights are green and showing everything is working I have factory reset everything several of times and unplugged everything and left it alone for a while then tried again and its still the same I have went onto the settings on both devices and I can not figure out what happened I just bought these yesterday and I'm very disappointed it's already not working.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Toshia_Renee
    Welcome to NETGEAR Community!
    May we please know who is your Internet service provider?
    Kindly access LM1200 settings page and check for new firmware update.
    Blanca
    Community Team
    • KayHaley5's avatar
      KayHaley5
      Tutor
      I am also having the same problem. Using straight talk sim card inside modem. Worked great for a week and then unplugged to move to a different location in my home and exact same problem as described. Please help!
      • Blanca_O's avatar
        Blanca_O
        Hi KayHaley5
        Kindly describe the LED status of the device. Have you tried factory resetting?
        Blanca
        Community Team
  • Has anyone found a fix to this issue I’m having the same problem all the lights are green with a green blinking signal light but can’t connect to the Internet
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      Could you please advise which carriers SIM you are using with LM1200?
      Thanks
      John
  • LM1200, light is green...worked fine for 3 days then nothing. Router reset, hotspot reset and nothing. I need help! Working remotely in a rural area.
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      Please provide a model.json file and send it to me with private message.
      Thanks
      John
  • I also have this issue. Was there a fix for it? Mine stops working every so often.
