UK-based
Jan 13, 2018Luminary
M1 (MR1100) needs battery to update firmware
My suspicions expressed at the end of this post seem to be confirmed - apparently you currently need a battery installed in the M1 in order to update its firmware. If this is correct, it's a big prob...
MicW
Jan 14, 2018Luminary
What is the new firmware version number? Mine hasn't seen any new firmware for months.
MicW
Ignore the above, I just missed it ><
- DangerMouseUKMar 28, 2018Aspirant
Guys are we still on : NTG9X50C_10.22.03.00 or is there a newer version ?
Mine keeps randomly rebooting on this firmware thanks.- MicWMar 28, 2018Luminary
DangerMouseUKI just installed version NTG9X50C_10.25.01.00 last week here in Australia. It may be different in other countries.
- winger13Mar 28, 2018GuideWhy would a change log NOT be provided???
- UK-basedMar 29, 2018Luminary
DangerMouseUK: I'm in the UK with carrier EE and my M1 is still on NTG9X50C_10.22.03.00. I'm running it without battery on an upgraded QC 3.0 mains charger and a heat sink on top with the battery compartment cover removed to keep the temperature down. Current temperature is 35 degrees and it's been connected for 12 days without reboot. It's connected to a Gb Ethernet switch, which has 2 access points attached. What's your setup?
- JasonNApr 03, 2018NETGEAR Employee Retired
Hi everyone,
My internal team are working on a new firmware at the moment. It will be release to everyone when they are finish.
Please be patient.
As for buying a new battery for the M1, we do not sell the battery separately. I'm sorry for the inconvenience. There are users on here that posted in the community with an alternate option. :]
- Jason N
- BeAuMaNApr 04, 2018Tutor
Thanks for the update, though I still stand by my opnion that the Service Providers are ill suited at the job they've been assigned in this relationship.
So, a bit of a clarification: The issue wasn't that AT&T didn't have the replacement batteries in stock, but that they didn't have them in their system at all. I contacted AT&T about a replacement, and the very helpful CSR said they would pass information along. I then also contacted Netgear about this issue to hope that having two people on each side tryign to resolve this would work. This was 3/7/2018.
As I was writing this reply, I though I should check again with AT&T, and I'm happy to report that AT&T does have the battery in stock now. They're going to ship me a new battery under warranty coverage, and it will take 8-10 business days to arrive. While this doesn't solve the other numerous issues with the device, at the very least AT&T can supply new batteries for it to customers.
