GDSR5
Aug 16, 2025Aspirant
M7 Ultra Pro - external antenna
With the M7 Ultra diesel the modem transmit wifi signal from the external antenna or just receive signal. I have a M7 in a locked container and would like to receive 5g signal and transmit a wifi signal from within the container. Thanks
TX and RX - but only for the mobile network,, including 5G services - not for the WiFi.
Yes, ethernet and wifi work at the same time. If it was me? I'd just connect a access point to it. Or you could use a full router and put the M7 in passthrough mode. Both options would work. Metal containers are great at blocking wifi. (and trapping heat, might need a vent if its a small container)
- GDSR5Aspirant
Thank you. Another question. Does(can) the ethernet connection operate as well as the wifi connection at same time?
- rcpaxLuminary
just to clarify what was already stated, the external antenna ports on the M7 is for 5G/LTE radio, not for WiFi. WiFi signals are sent and received via internal antennas in the device and there is no external port for you to connect WiFi antennas.
