GovernorNG's avatar
GovernorNG
Follower
Jun 25, 2025
Mobile Call
How can I make and recieve mobile call form the sim in the my router, when my laptop is connected to Nighthawk MR1100 router?
1 Reply
  • You cannot directly make or receive mobile calls from the SIM in your Nighthawk MR1100 router through your laptop, as the router is designed mainly for internet access, not voice calling. However, if your SIM supports VoLTE and your network allows it, you might be able to use VoIP services like WhatsApp, Skype, or Google Voice on your laptop to make calls using the internet connection provided by the router. For regular mobile network calls, you would need to insert the SIM into a mobile phone.
