Chris0404
Mar 22, 2018Guide
Mobile hotspot LTE MR1100 won’t stay on when connected
This device will not stay on when connected to anything. It auto shuts off and the only way to get it back on is to remove and reinsert the battery. I have already swapped it out with another brand ne...
UK-based
Mar 29, 2018Luminary
If you're using the MR1100 as a static 24/7 modem/router, you'll probably find that running on an upgraded QC 2.0 mains charger without the battery installed will cure the problem. I used this charger and took these actions to keep the temperature down. Other providers of QC chargers are available :smileywink:
- Chris0404Mar 29, 2018GuideYeah I wasn’t trying to use it as a static or stand alone 24/7 router. I couldn’t even use the device on battery power for 15 minutes without the device powering down and NOT able to turn back on. I have fiber home internet. I need a portable device. 2 of these devices didn’t solve that for me.
- UK-basedMar 29, 2018Luminary
Chris0404: I know this isn't by any means ideal but perhaps you could try reducing the current draw to a minimum by doing things like switching off the 2.4GHz Wifi and just relying on the 5GHz, reducing the WiFi Range to Short, enabling WiFi Standby, etc. This might indicate whether or not the problem is a power or perhaps temperature issue.
- Rcracerg911Mar 29, 2018AspirantI have tried reducing range and using a single band, including factory resetting and not changing any of the default setting and no change. There is are specific areas that sometimes causes the unit to shut off more than once within an hour while on battery. Can’t test plugged in because I’m on the move but Starting to think it might be trying to aggregate frequency’s and it’s failing somehow. Just a though, not sure.
