Watson306
Jul 22, 2022Aspirant
MR1100 - Unable to update firmware
Hi Guys,
I have a MR1100 MiFi and if i use the automated search for firmware it says I have the up to date firmware.
But if I search on the webite it says there is a more up to date version.
But if I try to manually update the FW it says its not suitable for my device.
So currently the FW is - NTG9X50C_12.04.02.00
The PRI is - 03.03
Not sure what I am doing wrong or if it is indeed the most up to date version?
PS on a side note - could someone tell me what the most up to date charger for this device in UK is?
Many Thanks in advance
There exist at least half a dozen different MR1100 models. Firmware is not exchangeable, band plan and modulation versions is preconfigured and depends on the carrier and/or market requirements.
- Watson306Aspirant
Thanks for your reply.
Do you know where I can find out the version I have? - richallcornAspirant
After reading some of the posts here, I would NOT recommend updating the firmware. One guy posts that his unit suddenly became a battery hog and battery life went down considerably. Whats that old saying, "If it ain't broke, don't try to fix it." LOL
Good luck ...
-rich-Rich Allcorn
http://rich.allcorn.us
