joepgal
Dec 19, 2021Aspirant
MR1100 broadband disconnect
I had to do a factory reset on this device and now when it comes back up, will not connect keep getting broadband disconnected. This is on a Cricket network, not Tmobile. I have the latest firmware, I have changed to LTE instead of auto. I am not sure what else to try
- JohnPengNETGEAR Expert
Did you try to set up the correct APN for your SIM card?
Thanks
- joepgalAspirantThat was the issue. It had an AT&T apn in there. Thought that since AT&T owns cricket, that was correct one. I added cricket and connected immediately. Thank you
- JLuckyAspirantI have installed an EE SIM card but it’s saying mobile broadband disconnected. I have done a reset.
Any ideas for someone with basic tech knowledge gratefully received.
