Dorian123's avatar
Dorian123
MR1100 Force Firmware Check/Update
I'm currently running 10.20.05.00.
I had a pending firmware update (to .02) which I had not run before doing a factory reset.
When I check for updated firmware now, the router says it is up to date (it isn't), and it won't let me re-check without another reset.
How do I force the hotspot to grab and install the latest version?
  • I'm in the UK and my carrier is EE. My firmware version is currently NTG9X50C_10.22.03.00. It's quite likely that the version numbers differ between countries and carriers, due to customisations. So your web-based interface may differ from mine. Anyway, in my web interface the Settings > Administration > Firmware Update section has a button "CHECK FOR UPDATES" with the date of the last check below it. Are you saying that this button either isn't in your web interface or isn't clickable?
    Another option would be to try the Netgear Mobile app under Settings > Firmware > "CHECK FOR UPDATES". If you don't already have the app, here are the locations of both the Android and iOS versions. Both my web GUI and the app indicate that my M1 is doing a regular auto-check without my intervention.
    I suppose there's one other reason why your M1 won't update to the .02 release - it may have been deleted from the Netgear site (or wherever it's hosted) due to issues. The problem with this hidden auto-update system is that we never know what releases are available and we have no clue what new features and bug fixes have been implemented because no changelogs/update history files are publicly available. I hope Netgear make these available in future - I'm sure this would reduce the number of support requests they receive.
    • Dorian123's avatar
      Dorian123
      The “check for update” button exists. However, it can not be pressed repeatedly. In other words, after clicking the button, it disappears and is replaced with the text “The software is currently up to date.” No amount of reloading the page or switching devices brings the “Check for update” button back.
      • UK-based's avatar
        UK-based
        Luminary
        I've had a similar problem in the past but it resolved itself. My guess was that for some reason, the location where the updates are hosted was inaccessible.
        Two questions:
        1. Have you tried both the browser-based interface and the Android or iOS app?
        2. Are you running the M1 without a battery on just the mains charger? If so, my experience is that it won't upgrade the firmware. It requires the battery in situ with at least 20% charge. See this post.
        Regarding the version numbers, I checked back through my previous versions and see that I was also on NTG9X50C_10.20.05.00 just before it auto-updated to NTG9X50C_10.22.03.00. See this post on version numbers. Are you also in the UK with the carrier EE?
