klbcolt
Dec 16, 2021Aspirant
MR1100ATT factory reset does not show the wifi password on the display
I bought a used MR1100ATT to replace one that stopped working recently. After plugging it in, it starts up wifi and I then try to connect to "ATT-WIFI-kPGT". However, the display screen on the MR1100ATT just shows "Setup Required" and not the default wifi password. Does anyone know the default password? Thanks! Kevin
Never mind. I removed the battery and the label underneath has the password. Duh!
1 Reply
- klbcoltAspirant
