EmilyBieman's avatar
EmilyBieman
MR2100 – Nighthawk M2 Mobile Router - faulty modem with no response from Netgear
How do I get a replacement on a faulty modem - when Netgear refused to speak to me, whenever I call their 1300 number, they hang up on me, and btw, Telstra charges $2/m to call 1300 numbers, one time I got through on their landline to Chatswood head quarters, and they put me on hold for 50 minutes and then hang up on me? and once they daid I had to pay the $49 to talk to a techie, (when it is stil under warranty) And telstra has advised me, after running threough troubleshooting steps, it is FAULTY
This is still under warranty they refuse to replace repair or refund and even talk to me it’s like I have no choice but to take them to court if I want my money back. Talk about a disgraceful business. chatswood - north shore wannabes
  • finally someone from Netgear reached out via email, and put me in contact with a Telstra guy (Felix) who replaced the modem. (turns out it was Telstra who shoulkd have replaced the modem in the first place, but for some reason they refused, until Netgear intervened) So now it works just fine.
    Someone has put spelling mistakes in all my above posts.
    https://emilyconstancebieman.wixsite.com/blog
  • schumaku's avatar
    schumaku
    Dear Emily,
    You mix two things up here and in the video. The MR2100 model is clearly a Telstra branded unit. Any warranty and service has to come from Telstra therefore. Netgear is only the manufacturer or OEM of your device as this is not a Netgear device model sold in the free market. It's also not Netgear's problem if your carrier does charge that high rates on what should be a customer support line. [Edit] Probably not reading properly - of course also NEtgear can charge something for thir support line [/Edit] Over here in Europe this would be illegal to start the counter before a call is answered.
    Not sure where/how you call Netgear - in most markets, a support case must be created and filed online first before we get a phone number to call. Ah, Austraia might be an exception. No idea why you fall off from the line attempting to call Netgear - this should not happen. Either way, they won't be able to provide you with a different answer for the Telstra M2/MR2100.
    Essentially, this post should be in the Mobile Routers, Hotspots & Modems - I'll notify the moderators to move (both) of your posts. In the meantime, I hope Blanca_O can provide some more advise on potential troubleshooting.
    -Kurt
    • EmilyBieman's avatar
      EmilyBieman
      Thanks Kurt, yes, I can see the big T on teh device, but teh girl at Telstra shop, and teh boys on teh telstra techincl call centre all said it is  a netgear problem. And this model is sold in the free market. And yes it is Netgears fault of teh high cost of 1300 numbers, as money made from those 1300 number goes directly to the company, NOT telstra - busines's make money  (steal from people) on 1300 numbers. And since this device is clearly faulty, it needs to be replaced, there are no need for questions to be answered. And, I will post in the Mobile Routers, Hotspots & Modems too
      i did not mix anything up KURT
      • schumaku's avatar
        schumaku
        No doubt it's a [Netgear] hardware issue, however - even if sold in the free market - it's a Telstra branded product, marketed and sold under their brand, specifically cutomized for the 3G and 4G bands used; with or without SIM lock, typically as a [discounted] hardware in a bundle along with a service contract, and also offered as part of thier services.
        In the common OEM/branding deals, support and warranty is delegated and must be provided (or at least initiated) by the brandig company, not by the manufacturer.
        Either way, head online to https://www.netgear.com/support/contact.aspx and proceed to "Replace my defective product" - this is the much faster and more reliable way than sticking in a phone waiting queue.
        EmilyBieman
        see your phone does not work, it just hangs up - REPEATEDLY
        AND
        Agent: 12502, stop sending me surveys, and sort the faulty modem, wakey wakey
