Streetfox
Dec 13, 2022Aspirant
MR2100 INCORRECT BATTERY INSERTED
Hello trusted community. I have a Netgear MR2100, which the battery has failed and will not charge. It works perfectly without the battery installed ie connected straight to the USB port. I purchased a new battery and now have an error incorrect battery installed. The battery voltage is in line with that of the failed battery, and looks identical in appearance. Hopefully someone can advise a solution. Thanks
- JohnPengNETGEAR Expert
You need to check the battery P/N number printed on the battery label.
The compatible battery for M2 should have the P/N:
308-10077-01
Thanks
John
