dhd2026
Mar 11, 2026Aspirant
MR6110 WiFi Schedule fails to work
Hi all,
I have a Nighthawk M6 MR6110-1TLAUS Mobile router that I am having an issue with. It is running on the latest firmware, NTGX65_12.01.41.00
Every time I try to setup this device to have a schedule to set when the hotspot is usable, the second you enable the schedule (even if there is nothing set) it will disable the WiFi. Even if you create a schedule with a set time, it does the same.
It seems that when the schedule is set to 'enable' there is a kill-switch on the hotspot availability.
Does anyone know of any work arounds to this?
Thanks in advance,
- dhd2026Aspirant
Yes, tried with several different schedules. I found that once the schedule was set to 'Enabled' the device would immediately stop allowing for hot spot access, regardless of the time frame
did you try changing the times that you used for the scheduler?
- dhd2026Aspirant
Interesting. I factory reset mine and it didnt make any changes. The minute I set the scheduler to enabled, it didnt matter what the schedule was it disabled the WIfi and didnt return back to service :(
I did. It worked on mine. Did you try my recommendation?
- dhd2026Aspirant
Hi Plemans, did you learn anything from your test?
Might try a reset because I tried the schedule on mine and it worked fine.
Also something else to try, if I remember correctly, it struggled if the time was set at 00:00. So if you're using that for a time, go for 00:01.
I've got an MR6110. You've got me curious. I'll charge it up and test it later to see what results I get.
