jraffel's avatar
jraffel
MR6450 and MacBook M2 don't connect on 6GHz
Hi Netgear,
I got the new MR6450 and a new MacBook Pro M2 both are able of Wifi 6e on 6GHz (tested that with other devices) but they just don't work together on Wifi 6e 6GHz. Why?
Cheers Jörn
NTGX65_10.04.25.00
macos 13.2.1 (22D68)
  • plemans's avatar
    So everything but the macbook works on the 6ghz?
    Seems to point a finger at some setting on the macbook causing issues.
    did you contact apple?
    • jraffel's avatar
      jraffel
      No actually the MacBook Pro works totally fine with a AXE5400 Tri-Band Gigabit Wi-Fi 6E Router. Insane DL speed and nice Ping.
      • plemans's avatar
        So then I'm confused what issue you're having.
        A little more clarity might help for what the issue is.
  • Tried with NTGX65_12.01.05.00 with Dell laptop (installed Intel AX210) has no issue with WiFi6E connection, works as expected. You might want to upgrade your FW over latest version
    • michaelkenward's avatar
      michaelkenward
      A lot of problems reported here with 6 GHz wifi have been down to the drivers for the WiFi. Dell and Mac are completely different.
      I still think that plemans was on the right track.
      • W1lliam's avatar
        W1lliam
        Virtuoso
        Suggest to have MR6450 landed on PSC channel to see if that improves, I am having 2.4+6G set to WiFi profile
    • Mouze64's avatar
      Mouze64
      I have the NTGX65_12.01.05.00
      PRI 01.07
      Nothing newer available
