Gramp
Sep 26, 2023Aspirant
Mr6500 where do I find admin password
There's a small hole under the cover in a slot on the connector side of the device. It will say reset near it. Use a wire probe (straightened paper clip).
Push the reset button in the hole for 10 seconds with the battery attached and charged. That should initiate a factory reset.
- JT240ZLuminary
Assuming that it's still the factory default, then it should be on the label under the battery. If it doesn't work, then you need to do a factory reset and try again.
- GrampAspirantI’m currently locked out on the iPad accessing m6. Because of the password issue. Do you know how to do the factory reset from the device it self?
- JT240ZLuminary
- GrampAspirantI tried the one underneath the battery. I’ll give the factory reset. Thanks for the feedback.
