bigs_
Jan 13, 2026Follower
MR7400 (M7 Pro AT&T)
I've got it setup, firmware updated, but I'm unable to change specific settings like WIFI settings, even disabling/enabling wifi is not enabled, either on the device or through http://attwifimanager/.
A number of settings are simply greyed out and you're not able to interact with them.
After factory resetting, I notice the settings are interactable for a brief time before the device restarts (out of no where) - I was actually able to update the wifi standby setting before the restart happened. Then they return to being disabled, grey options - but the setting that I did change before being disabled persisted as the value that I set.
Super weird, could be firmware, or a faulty device because I don't see any other threads discussing the same thing.
1 Reply
- user-not-foundFollower
Yikes... I have my own issue with the M7 Pro but not this bad... There was an update that I saw become available in the last week or so. After the update I have
Firmware version: NTGX75_10.04.43.00
Software version: MR7400-1a1NAS_04.17
Web App Version: M7_ATT_v07.01.80.00
Perhaps if you have lower version numbers applying the update might help?
