RobotPirate's avatar
RobotPirate
My new Nighthawk M1 hot spot sometimes gets in a loop with "netgear" screen and will not start up
Just got this earlier this week
Also sometimes when it is cold it keeps reboting, what do I do?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise whether your device SKU is MR1100-100NAS. If so, please advise the FW verison and PRI version on the device.
    What is the carrier you are using with M1?
    Thanks
    • RobotPirate's avatar
      RobotPirate
      My device is the MR1100-2A1NAS
      Firmware Version NTG9X50C_12.06.21.00
      We use ATT as a carrier
      The device is working now but sometime when plugged in using no battery, it gets in a loop, shows NETGEAR on screen, then the ATT LOGO, then repeats 4-5 times and I have to unplug device to restart the cycle
      Also it restarts sometimes when I click "connect" on my PC, it will instantly reboot
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        AT&T just released a new update with FW version 12.06.39.00. Please upgrade to the latest version and see whether the issue goes away.
        If you use a device heavily, better to insert battery or use a QC PA when not using battery.
        It is a typical sign that PA can't provide enough power when using no battery and clicking Connect button results in device reboot.
        Thanks
        John
