djbeast
Nov 26, 2017Aspirant
Netgear Aircard 790S problem connecting to Nintendo Switch
Hello. Im new here and I need you help please.
Im having problem connecting my Nintendo Switch to my Netgear Aircard 790S to play online games. Im getting and error on Switch that says : Unable to connect to the other consoles , please try agan. If I push details , it reads NAT traversal process has failed.
If I try to connect from my homes network , everything is fine. Also if I remove my data SIM from my Netgear and place it to my smartphone , it works fine!
Is there a setting for the Netgear so I could do to fix the problem? Please help!
Thank you
Thank you
- DarrenMSr. NETGEAR Moderator
You may need to do some port forwarding for the nintendo switch.
DarrenM
- djbeastAspirantHow do I do that?
Can you please help me?- DarrenMSr. NETGEAR Moderator
Here is how to enable port forwarding
https://kb.netgear.com/23675/Enabling-Port-Forwarding-Filtering-on-an-AirCard-Mobile-Hotspot
Here is the ports you will need to open.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/651/~/how-to-set-up-port-forwarding
DarrenM
