RdWarrior5126
Jan 23, 2022Aspirant
Netgear LB1120 : VoLTE support? hotspot usage?
Suggetions for best option for a 4g VoLTE supported mobile wifi hotspot??
Would Netgear model LB1120 be a good choice??
THANKS in advance for kind assistance.
- JohnPengNETGEAR Expert
LB1120 doesn't support VoLTE. I don't think we have WiFi hotspots support the feature. But you can find some fixed wireless products support this.
https://www.4gltemall.com/netgear-mvbr1517-4g-lte-voip-volte-router.html
Thanks
- RdWarrior5126Aspirant
Thanks very much for reply. To clairify , Netgear does not currently have any cellular 4g VoLTE mobile hotspot products for sale, correct?
Due to my deployment locations , need a cellular 4g VoLTE compliant mobile hotspot. Any suggestions would be appreciated.
THANKS!
THANKS!
For VoLTE service, better to consult with the carrier that you plan to use. Sometimes, VoLTE service requires carrier support. BYOD may not work.
Thanks
