AlKhald's avatar
AlKhald
NETGEAR MR1100-100EUS Routeur mobile Nighthawk M1
An annoying problem in the new update with NETGEAR MR1100-100EUS Routeur Mobile Nighthawk M1
It restarts every minute
  • Hello dear brother
    Thanks and appreciation for your help
    I did all the solutions, the problem came from electricity and I did a lot of tests.
    Does not support native power after 5V update
    Which was really annoying I used Power Anker 18W
    The problem has been resolved
    The type used for the solution is
    Anker America's leading USB charging
    I also experimented
    On Samsung
    Power of 5/9 volts
    But Power Anker is the best in terms of stability
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi AlKhald
    Welcome to NETGEAR Community!
    Was it working fine before the upgrade?
    Do you have the battery inserted?
    Have you tried resetting the unit?
    Blanca
    Community Team
    • AlKhald's avatar
      AlKhald
      Hello dear brother
      I also experimented
      On Samsung
      Power of 5/9 volts
