beanonymous89's avatar
Jul 29, 2018
Netgear Nighthawk M1 - Telstra - fireware Update
I have a few Nighthawk M1's that are used as a 4G failover at clients sites and I have had a lot of trouble with these units going to sleep when I need them ready at a moments notice.
Now I have found that some of these Nighthawks are able to download the new (2018) update directly over the 4G connection they are on, which contains the fix that prevents the timing out / sleep of the unit but there is no where online, that I can see, to manually download and upload this firmware update for some of these pesky M1 units that cant seem to locate the update.
Can anyone please assist me on this one?
  • Hello everyone in the community, I'm new here, I don't know if you'll see my message. I'm from Brazil and I have a Telstra Netgear M1 router. Yesterday I tried to install firmware on it and, after that, the device no longer recognizes my carrier's SIM card. Has anyone here experienced this problem and managed to solve it? If it's solved, could you help me solve it?
  • Hi can I please also get the firmware upgrade file for a non carrier locked device?
  • Are these AT&T units?  The firmware comes direct from them over the air.  Log into the Admin interface to via a web browser to check for updates.  Similarly, you can disable the Ethernet timeout via the web interface.  There have been multiple firmwares in 2018 (for AT&T).  The newest (from June) seems pretty good.  My unit (Gen1) is much more stable now.
