v5_rnas
Mar 01, 2017Aspirant
Netgear Nighthawk M1 drops LTe connection every day and requires multiple reboots
Hi there,
Purchased a Nighthawk M1 (MR1100) from Telstra recently. Seems to work well in terms of speed. But a few problems including severe lack of configuration for DHCP (the only item you can configure is DHCP range - there's no fixed host mappings, or any even basic features present in almost every other device on the market. I really hope this is addressed in a future patch or Netgear advise a secret menu to access these basic features as it's really disappointing and lets the router down at the present time). However, it's by far the fastest I've ever tested.
Anyway to the main problem. Every day when I come home the device is no longer providing Internet over the connected ethernet cable. I can connect to the modem admin screen fine, and it reports it's connected to the internet (reports LTE connection is fine and has been connected for over a day); however, no devices on the network can use the internet and the only way to solve it is by restarting the MR1100 multiple times eventually it starts routing traffic again. This problem does not occur on any of the other modems I've tested using the same SIM/Service so it's definitely an issue with the MR1100.
Something is wrong with the software - need someone from Netgear to sort this out.
Also Netgear you need to add the Nighthawk M1 to your model list as I had to assign this ticket against a random unrelated modem as your product list isn't up to date.
I am having the same problem. Incredibly not-fit-for-purpose.
I can hardly expect my 3 year old to get up in the morning and reboot the router before playing with his iPad every morning. I'm contemplating a return as these challenges are quickly rendering it not-fit-for-purpose.
I should add this is a problem for me on wired ethernet connection to the device, as well as wireless connection to the deveice - it loses the 4G connection to the mobile phone tower.
- ArodiDNETGEAR Expert
HI v5_rnas,
I have sent you a PM. Please check when you have some time.
- papajohn3002Aspirant
Like others before me, I'm fed up with having to reboot my Nighthawk MR1 every time I stop briefly on my computer (MacBook Air) or when I close down my computer. I used a Sierra mobile router before which never required rebooting. The Telstra technician suggested changing the time-out feature under "Advanced" to "Never" but this makes no difference.
Can you please help?
papajohn3002
- ElaineMNETGEAR Employee Retired
Moving this under Aircard LTE Hotspot & Gateways.
