mengnighthawk's avatar
May 19, 2021
netgear nighthawk m1 keeps slowing down
I have a mr1100 that is connected to a router, followed from a YouTube video. anyways, my internet connection is att unlimited. my issue is that my internet speed keeps slowing down from 100mbps to less than 10mbps. I keep having to reboot the mr1100 which will keep the speeds up for about an hour or two then slows down again. it used to never do this until about a month ago. option LTE all is used and correct apn name is also used. what can I do to not have to keep rebooting the mr1100
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please do a factory reset and try again.
    If the issue still happens, please check with AT&T whether the network throttles your data.
    Thanks
    John
    • bkelling's avatar
      bkelling
      JohnPeng  could you please help me; i am having the same problem as him above and my router is extremely slow....also when i try to plug in the usb c into my xbox to have a direct tether for faster wifi it does not tether...i have selected the setting charge+tether but still does not work...anything helps thanks......I am unsure what you meant by your response to him above also
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        The device can be tethered to Windows or Mac due to default drivers loaded on the operating system. I don't think your XBox has the supporting driver for the device. That is why USB tethering will not work on your Xbox.
