Abbud7's avatar
Abbud7
Netgear Nighthawk M1 MR1100
Hello,
Recently I bought a Nighthawk M1 MR1100 and it was working fine until I updated the firmware. I want to know if there is a way to downgrade my firmware. I think it’s because of the update that my internet is slow. Please i need help.
  • Go to the support page downloads for your model and you can locate previous firmwares.
    I recommend resetting via the reset button and then upgrade/downgrade, but it's not necessary to reset first.
      • additude's avatar
        additude
        Virtuoso
        It appears that is the only version available. There are no previous versions.
        The firmware version ending in .00 may be an indicator that there are no previous versions, but naming conventions are of their own accord and only mean something in relationship to each other.
        In the past I have found on the "Download" page for my Netgear equipment that there is a seperate link to previous versions of firmware. That link is not available here so there must not be any previous versions.
