Sullos
Feb 15, 2017Follower
Netgear Nighthawk M1 Portforwarding Issues
I recently bought the new Nighthawk M1 4G LTE Mobile Router in an 80GB plan from Telstra, everything works well so far, I'm getting at lowest 50mbps, -land so far at highest ~120mbps, either way I'm h...
ArodiD
Apr 03, 2017NETGEAR Expert
Hi Sullos,
I have tested Port Forwarding using RDP after seeing your post and can confirm port forwarding is working fine with the M1. Can you please advise what APN profile you are using with the M1? If you are using the standard Telstra.Internet APN profile then no matter what you do it wont work as that APN profile is NAT'd. You will need to contact Telstra and ask them to provision Telstra.Extranet on your SIM card and then you will need to manually setup the APN profile in the M1.
Kind Regards,
ArodiD.
