mmbitang's avatar
mmbitang
Follower
Mar 16, 2022
netgear Nighthawk M2 - boot screen problem
please help me on my M2 just bought this router dated 3/16/2022 what should I do on the problem please....
note: power button is responding.
and the lights is blinking red
and the wifi is disable so can't manage it?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi mmbitang
    Welcome to NETGEAR Community!
    Can you try holding down the factory reset button for longer than 5 seconds?  Hold down until you see a change in the LED's then let go and see if that forces a factory reset.
    If issue still unresolved, kindly contact support to better isolate the issue for possible hardware problem http://www.netgear.com/support/contact.aspx
    Blanca
    Community Team
  • I have a similar problem - 2 dots on the boot screen and a red blinking LED. My MR2100-1TLAUS can be switched to boot mode, but the firmware has all been removed from the Netgear website. Now it remains only to throw it away if I do not find the firmware anywhere. Netgear administrators Can you explain why all MR2100 firmware was removed?
    • musashi84's avatar
      musashi84
      Hi,
      Same Problem Here. Any Response?
      With BooT Mode You You Mean?
      thanks For Any Kind Of Help
