Danielaurence's avatar
Mar 10, 2023
Netgear Nighthawk MR1100 M1 Frozen on Boot Logo with Solid Amber Light and Won't Hard Reset
Hello,
I have been using an M1 mobile router with an AT&T sim card for my rural home internet, but recently, when turning on the device, it has frozen with just the "NETGEAR" boot logo and a solid amber light. This happens every time the device is booted up, and it is completely unresponsive. It will not power down, hard reset, or be detected when connected to a PC. The only way to power it down is to remove the battery. I have tried removing the sim card and holding down the reset button, but it is completely unresponsive.
IMEI: 015161000747447
SKU: 6420B
Any troubleshooting help is greatly appreciated, as I rely on this device for my work. Thank you.
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Danielaurence wrote:
    Hello,
    SKU: 6420B
    If the device can't boot up without SIM, it may be broken permanently.
    Thanks
