nglcour's avatar
nglcour
New firmware causes no connection with mobile network
Hi,
Since the firmware update to this device last month I haven't been able to get the device to connect to the EE network, despite a reset and reentering the APN settings.
How can I go back to the previous firmware?  Whenever I go into the settings via the web I try to manually select an EE network but it seems to pivot to o2 by default - not sure if that's a fault with the firmware upgrade.
  • Just spent a couple of hours trying to resolve it. An EE sim not working, but a 3 and O2 sim worked fine.
    (Seen a response on O2 forums about it not working with O2, but working with EE)
    Solution was to add a secondary APN (default is 'btinernet.bt.com', secondary is 'everywhere'), set the connection to 4G only, change to a different APN (default --> secondary) and it started working. Then we changed it from 4G to 4G+5G and then back to the default APN.
    My theory is that it's caused by the recent removal of 3G.
    • nglcour's avatar
      nglcour
      Whatever the cause your steps fixed it, much appreciated.
