Gina99's avatar
Gina99
Night Hawk M1
On the screen of the router it says - "Data usage not available at this time" It used to show our data usage until about 2 months ago and don't know why?
Any suggestions would be appreciated please.
  • Hi Gina99
    Please be informed that firmware upgrade has been released for MR1100 Telstra Variant. This is to address the data usage issue not available. Kindly check your device for new firmware update and provide feedback.
    Firmware version is 12.06.08.00
    Blanca
    Community Team
    • Gina99's avatar
      Gina99
      HI,
      I FOUND THE SKU DETAILS SEE ABOVE. ALSO WE RECENTLY UPDATED FROM 10 GB  TO 50 GB SO COULD THIS BE WHY IT'S NOT SHOWING DATA USAGE???
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Gina99
    Blanca
    Community Team
    • Nightwho's avatar
      Nightwho
      Hi Blanca,
      I tried to update the new firmware for a friends, who has the Nighthawk M1 Mobile Router.
      To my surprise,the update didn’t download. The text box said “ Update Error ,The update couldn’t be updated and the mobile router will automatically re-check for an available update within 48 hrs “
      Can you tell me what’s happening with this new firmware  not being able to download.
      I did the manual update but this also came up with a error.
      kind Regards
      nightwho
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        Please let me know your device SKU name. I will check for you.
        Thanks
    • Gina99's avatar
      Gina99
      Thanks so much for everyones help. All sorted out now and working fine!
