galvesribeiro
Apr 24, 2023Tutor
Night hawk m6 mr6150 error
Hello folks!
Just got my brand new Nighthawk M6 5G unlocked hotspot (MR6150) from Netgear store on Amazon (https://www.amazon.com/dp/B0BGV79FHT?ref=ppx_yo2ov_dt_b_product_details&th=1). The initial setup was smooth, I've configured the APN but then the device keeps "Searching" for my network.
I'm using a SIM card which is from a data plan, and which I tested on an iPad using the exact same APIs. It works there, and the Carrier says there is no blocks on it.
The M6 keeps showing error 33 and ask for me to configure the APN.
Searching on the web I found out that this firmware update has mention to this "Searching" behavior:
https://kb.netgear.com/000065419/MR6150-Firmware-Version-10-04-22-00#
- Resolved an issue where the device is stuck searching and doesn't reconnect with the correct APN
When checking for updates (I made the Ethernet the principal internet connection) it show no new updates. Tried to find a download link from that KB to maybe force update or something like that, but there isn't any links or a clear place on where to download anything.
Can anyone clarify what should I do to get this working? My carrier don't have problemas as they work on a generic USB modem/router/stick and on the iPad, not on this Netgear device. This is a really expensive device and I really hope to not have it as a paperweight.
Thank you! I really appreciate any input here.
- JohnPengNETGEAR Expert
Please check your APN setting. I think you are using AT&T IPad data plan. You need to set the APN following the link below.
https://www.att.com/support/article/wireless/KM1062162/
You can also send me a model.json log to check further. You can send the file via PM.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
I'm not using the ATT APN. My carrier is Claro from Brazil. It works on both my iPhone and iPad where both where purchased in USA and they both works fine with the same SIM card.
I've shared with you a OneDrive link with the JSON file in it. It is too big for the PM.
Thanks!
Thanks!
Please send the model.json file to my email at jopeng@netgear.com. The one drive link didn't work somehow.
Thanks
John
