DamonEcosse's avatar
DamonEcosse
Follower
Apr 19, 2026
NIghtgear Nighthawk M6 - Nikon Z9 - FTP Settings
Hello there,
I have recently purchased a Nightgear Nighthawk M6. I am hoping to set it up for sending FTP files from my Nikon Z9 to my Macbook and to find out the best and most efficient settings.
This is for sports photography and I need the images to be sent as quickly as possible without bottlenecks. I was hoping that having the Nighthawk would enable me to use the 5ghz channel but unfortunately this does not seem to be recognised on my Z9. The 2.4ghz channel is showing but it doesn't seem to be working particularly well. I tried it out for a game yesterday and it was only able to send a few files before crashing and slowing down to a stop. Also some of the images that it sent were duplicated as well as some of them being being unable to open as they were damaged.
Is there anybody out there who has experience of using the NIkon Z9 with the Nighthawk or a similar setup? I would greatly appreciate if you could help me set up the server with the camera. I am a little bit confused by all of the settings and really hoped that it would be simpler than this.
Any help or advise would be greatly appreciated.
1 Reply
  • schumaku's avatar
    schumaku
    Assuming you operate a Nikon WT-6 or WT-6A, before defining the wireless profile select the desired WiFi band to be used:
    [Wired LAN/WT] > [Options] > [Router frequency band] and choose the desired band. Select [2.4 GHz] or [5 GHz] to connect only to networks operating on the chosen band, [2.4 GHz/5 GHz] to connect to networks operating on either band.
    Older Nikon WiFi Wireless Transmitters might use a feature named WiFi Direct (and designate it misleadingly as Access Point Mode in the docs) - which might be restricted to 2.4 GHz because of regional/worldwide regulatories.
    DamonEcosse wrote:
    I have recently purchased a Netgear Nighthawk M6. I am hoping to set it up for sending FTP files from my Nikon Z9 to my Macbook and to find out the best and most efficient settings.
    In this case, the M6 does serve as a wireless access point for the Z9 (operating in Infrastructure Mode 8-) ), the MAC can either be connected to the WiFi, or by Ethernet which needs to be enabled: Advanced -> Mobile Router Setup -> Ethernet -> check to enable, probably allowing some better performance than sending large amounts of photos and videos over the WiFi twice (Z9<->M6 and M6<->Mac) - permitting you have a Mac with a built-in Ethernet LAN port) to the M6.
    I'm not deep in the M6, hope it does work in general like a common WiFi router.
