mrsjlb's avatar
mrsjlb
Nighthawk 2100. Can i connect a wireless router to extend range,
Nighthawk 2100. Can i connect a wireless router to extend range.
        Jean
  • plemans's avatar
    not sure what the nighthawk 2100 is as it isn't a model number.
    but any of netgears router should be able to have an extender connected to it.
    You can even connect an extender to their mesh systems but it just doesn't integrate with the system.
    • mrsjlb's avatar
      mrsjlb
      Hi the model is a netgear Nighthawk M2100 mobile router
        Jean
  • michaelkenward's avatar
    michaelkenward
        Jean
    How do you want to connect the router to the M2100?
    I can think of three options:
    • router plugged into the M2100 in modem only mode
    • router in access point mode plugged into the M2100 in modem/router mode
    • wifi connection between M2100 and router
    There may be other options.
    • mrsjlb's avatar
      mrsjlb
      So Sorry for the late reply. Thank you for all your help. The range on the m2100 is not very good so i wanted to use m2100 as a modem and a wireless router for wifi range
        Jean
        michaelkenward
        Jean
        That shgould be possible, as plemans suggested.
        Did you investigate the three option I suggested?
        Also, there does not seem to be an "M2100" in Netgear's range of modes. So no one can advise you in which option your modem supports.
        Perhaps you mean MR2100.
        To help you to choose between the options, start by checking the manual
        Visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware.
