khairymadhoon
Feb 05, 2018Aspirant
Nighthawk LTE Mobile Hotspot Router Model MR1100 factory unlocked for any GSM provider
Hello,
I would like to ask the Netgear developer if the Nighthawk LTE Mobile Hotspot Router Model MR1100 will be available for retail so we can use any GSM SIM Card worldwide,
I do appreciate your prompt response.
Best regards,
Khairy
Hi,
Retail model launch is February. Please just do Google search MR1100-100EUS and you may find some shops which allow pre-ordering.
- TeeJay74Virtuoso
Hi,
- khairymadhoonAspirantThanks Tee.
- UK-basedLuminary
Does that mean that firmware updates for the MR1100 will be made available for "manual" download from the Netgear site, TeeJay74, so that people can update their MR1100 whenever they want, instead of having to rely on auto-updates?
- TeeJay74Virtuoso
I think OTA is going to be the only way.
