Alexp69's avatar
Alexp69
Nighthawk LTE mobile router stand by power usage
Hi all,
I want to install an LTE mobile spot serving an IP security cam on a boat where I have no access to shore power save for installing more solar cells. I need to calculate a power budget. I like the nighthawk hotspot since it has ethernet port so can plug the camera directly and save on wifi power. Usage will be very occasionally checking on the boat (so few secs/minutes video/shots uploads per week)) or as needed (alarms). Hotspot will basically stay 99.9+% of the time in stand by. What would be the expected power drain of the hotspot itself ? How long the 5000mA battery would last ? the spec'ed 24 hours life is with a quite heavy 66% downloading activity I understand. If I leave it plugged what would be the drain/loss in mA from the USB charger to keep the battery charged ?
Thanks
Alex
