ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
michaelkenward
May 17, 2017Guru - Experienced User
ajohnsonmc wrote:Plugged into the wallmount to charge ...
What's the "wallmount"? That's not a term that I am familiar with. Nor is Google in this context.
A transformer with a USB output?
