ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
jenjo77
Jul 18, 2017Aspirant
I received a Netgear Nighthawk M1 23 May 2017 as a replacement for one I received in March. The problem is similar and happened almost two months to the date –
- The Netgear has been working well, but last night it wouldn't recharge, and now it seems totally dead.
- It had recharged [via wall mount socket] to approx. 80%, and yet when I returned around 10 mins later the charge had totally drained so that there was only one bar in the battery image.
- I tried recharging instead via the USB port in my computer, and went to m.home, but while I still had wifi, for a brief tine, the page just kept trying to load. I checked a Netgear support page, and other people had had the same problem, with the battery draining rather than charging. They thought it was the adaptor.
- Now the Netgear won’t turn on, no lights, nothing. No lightning bolt to show charging.
- I have removed the battery and put it back in, and tried to reboot the router to no avail.
Is this common with Netgear Nighthawks? Should I buy a nbew battery? Is it the adaptor? Desperate minds want to know!
- ajohnsonmcJul 18, 2017Tutor
Hi there,
After advice from this site I used a different adaptor (wall mount) and the unit seems to be working fine now (at least for the last eight weeks). Good luck. A
- jenjo77Jul 18, 2017Aspirant
Thanks, A.
Telstra is replacing the Nighthawk since it is still under warranty, but this is the second time it's happened in exactly the same way, two months between each time. I'm getting spooked about the two month doom-time! I'll try it again and see what happens in september!
- CVDWAug 08, 2017Initiate
I had the same problems. I removed the battery. The Nighthawk even diden't startup without the battey on a 2.4 Amp. adaptor. I did try it over and over again, .........but
But afther I removed the sim (sim-card), it started without any problem. I put back the battery and could see the battery was almost completly loaded. Somthing about 80%. So my Nighthawk is working again.
I hope this wil work for others as well. Good luck
CVDW from Holland (I boucht the Nigthawk M1 in april 2017 at Telstra's Sydney, Australia)
- Zoomtank99Sep 16, 2018Aspirant.. Hence, you're entitled for asking a compensation over the router's charger, ain't you?!
