ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
JamesGL
Nov 09, 2017NETGEAR Employee Retired
Hi Dom198,
You have to contact Telstra and have it replaced.
ajohnsonmc
Nov 09, 2017Tutor
Hi there, this link is for an AirCard replacement request, not for the Nighthawk.Telstra won't accept it.
