ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
CVDW
Aug 08, 2017Initiate
I had the same problems. I removed the battery. The Nighthawk even diden't startup without the battey on a 2.4 Amp. adaptor. I did try it over and over again, .........but
But afther I removed the sim (sim-card), it started without any problem. I put back the battery and could see the battery was almost completly loaded. Somthing about 80%. So my Nighthawk is working again.
I hope this wil work for others as well. Good luck
CVDW from Holland (I boucht the Nigthawk M1 in april 2017 at Telstra's Sydney, Australia)
MeriA
Nov 11, 2017Aspirant
Same problem, won't charge, purchased in Australia.
So annoying.
Swapped chargers and powerpoints and so on.
Taking battery and SIM card WORKED!!
Good luck!
