ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
michaelkenward
May 17, 2017Guru - Experienced User
ajohnsonmc wrote:Plugged into the wallmount to charge ...
What's the "wallmount"? That's not a term that I am familiar with. Nor is Google in this context.
A transformer with a USB output?
glenndrums
Jan 31, 2018Aspirant
- TThumper89Jan 31, 2018AspirantI’m sorry glenndrums but I have no idea what you’re talking about, but nice mature response nonetheless.
- SouvorkinJan 31, 2018Tutor
People like that, with so much hate, arrogance and ignorance, deserve no reply and any reply is likely to be of little effect. Best to flag to moderator and get this person banned from the forum.
- michaelkenwardFeb 01, 2018Guru - Experienced User
Reported.
- glenndrumsFeb 01, 2018AspirantThe very first question in the thread - then the response making that person feel bad for calling the plug a “wall mount”
