ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
JasonN
Mar 05, 2018NETGEAR Employee Retired
Hi Tilba16,
Thank you for adding to the post. Please let us know with the new unit. Thank you again. :]
- Jason N
tilba16
Mar 11, 2018Aspirant
Afetr monitoring the unit for a week battery charge is at 100% and no further issues.
- Cage1010Apr 23, 2018Guide
Today, I received a firmware update message, and I finished the update.
Right now the firmware version is NTG9X50C_10.25.01.01.
FYI~
Not sure what is updated. No release log file.
- JasonNApr 24, 2018NETGEAR Employee Retired
Hi Cage1010,
We do not provide the firmware notes on these types of devices that use an ISP.
- Jason N
