ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
ajohnsonmc
Jul 18, 2017Tutor
Hi there,
After advice from this site I used a different adaptor (wall mount) and the unit seems to be working fine now (at least for the last eight weeks). Good luck. A
Zoomtank99
Sep 16, 2018Aspirant
.. Hence, you're entitled for asking a compensation over the router's charger, ain't you?!
