ajohnsonmc
May 16, 2017Tutor
Nighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB ...
Gmsutton
May 30, 2025Aspirant
I’ve had it with newer hot spots (after years of success). Now going to a router that hooks up to AT&T. Newer netgears don’t charge reliably even after using a timer to avoid over charging.
