The_Mule1987
Aug 14, 2018Tutor
Nighthawk M1 battery charging problem
Hi there , I recently bought the unlocked version of the m1 nighthawk router and it was great 3 days ago . Suddenly , a charging issue started to occur with no reason , when my battery died I plugged my router to a wall power socket and then I was shocked that the battery had charged until 97 % and did not complete 100 % . I then removed the battery and returned it back and then plugged back the router to the charger and still it does not charge beyond 97 % . So is there any solution to my problem ? .
- TeeJay74VirtuosoI have seen this happening with several MR1100-100EUS devices. I have reported this to Netgear and some investigation is going on, no results yet.
- TeeJay74Virtuoso
I managed to get full 100% charge after complete discharge/recharge cycle which took some time.
- Did you experience a non full charge before , if yes then what exactly did you do to fix the problem . I never charged my router before battery completely shutdown. I always charge when the battery is dead and still I don’t get a full charge
