asvphotographic
Feb 16, 2018Aspirant
Nighthawk M1 does not port forward and cannot get help from netgear
So I have a business account with telstra on the extranet apn and they adminantly say that it is not behind a CGNAt and that portforwarding should work and it is the modem at fault. I have also confi...
asvphotographic
When in DMZ mode the port scanner tool on the net says the following ports are open:
21
80
139
443
445
But nothing else. It says refused(RST)
antinode
Feb 17, 2018Guru
> [...] the Nighthawk M1 [...]
I've never touched one, so I know nothing, but there seem to be
multiple variants of that model. The actual model number (on the label
on the gizmo?) might be interesting.
> [...] I have tried DMZ and ip pass through and setting up
> portfowarding rules. and to no avail I cannot get my ftp server to
> work........
Not a very detailed description of anything. Actual port-forwarding
rule(s)?
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] Also is it true that you can not enter a range of ports into the
> m1 you have do it individually.
That's how I read the manual.
> ports are open:
> 21
> 80
> 139
> 443
> 445
I don't know what "It says refused(RST)" means. What is "it"? When
you do what?
Conventional (active-mode) FTP uses ports 20 and 21. You might get
by with only 21 if you use passive mode. You are talking about
plain-old, insecure FTP, not some fancy-new, secure variant (SFTP, ...),
right?
