asvphotographic
Feb 16, 2018Aspirant
Nighthawk M1 does not port forward and cannot get help from netgear
So I have a business account with telstra on the extranet apn and they adminantly say that it is not behind a CGNAt and that portforwarding should work and it is the modem at fault. I have also confi...
asvphotographic
Feb 19, 2018Aspirant
Thanks for your reply. Yes I have an ip that is the same as in the router networ status page. So I am on the extranet . However I need to know if anyone has an ftp server or any other server working behind the M1 router. Either the netgear modem is not port forwarding or there is still content filtering on the extranet network. I desperatley need to know if anyone has a service running behind the Nighthawk m1 on anynetwork ... Many thanks.
asvphotographic
Feb 20, 2018Aspirant
And should I just tick the box for DMZ and put in the ip address of the ftp server (A Synology NAS) .
Or is there more to that I need to do to make sure hte firewall on the model is open?
Many thanks.
