flixs's avatar
flixs
Nighthawk M1 doesn't see Arlo Cam
Hi guys,
I recently need my Nighthawk connected with 2 Arlo HD cams (not a pro, just a "cheap" probably older Arlo HD)
I was able to enable arlo at the Netgear and it should also been connected to the Arlo as it fills he SD card with videos, so however I can't manage to setup the Arlo App. I of course wants to have a live feed and setup motion detection, and play the videos.
I registered and have to then add the M1 + the cam(s) right?
When I add both it runs forever and fails.
Also I can add a base and it is searching, but I cannot choose M1 or something like i found in various 2018 videos.
Since the Arlo would be second, it doesn't find it as well-
Can anyone give some hints?
Firmware from the M1 is the latest 2020
    • flixs's avatar
      flixs
      yea, but with the Arlo app, and this doesn't see the M1 as base nor the cam
      • plemans's avatar
        it won't see the M1 as base. You actually need an arlo base with many of their models.
