johnliu
Jun 27, 2021Follower
Nighthawk M1 Mobile Hotspot shows "your data connection is disconnected"
Hi,
I bought a new unlocked device M1 MR1100 online, went to a local ATT store and purchased a data plan, plugged in the sim card, tried to connect my phone to it. The phone did connect to the hotspot, but it shows "internet may not be available". the message in the hotspot shows "your data connection is disconnected". The ATT store salesman could not figure it out. Can anyone help me out?
Thanks a lot,
John
- Blanca_ONETGEAR Employee Retired
Hi johnliu
Welcome to NETGEAR Community!
If you are connected to the mobile router but cannot connect to the Internet, try the following suggestions:
• Make sure that network coverage is available in your area.
• Make sure that your SIM card is active and enabled with data services.
• Wait one to two minutes for the mobile router to initialize.
• Confirm that your account is activated and that no other Internet connections are active.
• Switch your mobile router off and on and restart your computer or WiFi device.
Blanca
Community Team
- ChuckiAspirantAfter replacing the SIM card, I had trouble connecting. Followed all the various Troubleshooting directions to no avail. We are connected to our service but cannot yet connect to the Nighthawk. Even the Mobile app will not recognize this mobile router. Frankly, after two days of trying, I am my wits end. Please help.
- alvnas1500Aspirant
I just ran into same issue. Did you find a solution?
Router been running for more than a year without issue, but suddenly wifi disapeared and now it says "Data connection disconnected".
I have tried rebbot switching sim and factory reset without finding any solution.
Did you?
- JohnPengNETGEAR Expert
Did you?
Data connection disconnected means the device is not connected to carrier's network. Please check APN setting and check with yoru carrier whether the data service is blocked to the device or any changes on the service of your plan.
WiFi disappearance is a different issue.
Please send a model.json log to me by private message.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
