td1812090's avatar
td1812090
Follower
Sep 05, 2017
Nighthawk M1 Modem Firmware Update Ruined Connection
Hello
I have a Netgear MR1100 mobile wifi device and it worked great...UNTIL...the firmware update that it prompted me to do a few days ago.
Now the download rate is awful - dial up speeds. Especially on my laptop.
Facts-
- I have 4 devices on wifi from this mobile router
- I keep it fully charged and use it on mains power
- I have tried 3 factory resets to no avail
Any help greatly appreciated
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello td1812090
    You may want to contact Telstra support the may be able to get you the old firmware to load on the device.
    DarrenM
    • I have the same issue, telstra have been no help so far. the speed is on with 1 device connected but once a few are it slows to where some pages will not load?
    • sweete's avatar
      sweete
      Guide
      hahahahahaha
       I contacted telstra about getting the firmware reversed and telstra told me it was not possible!!!!!!!
      • yes i have spoken to Telstra advanced tech & Netgear tech support as well, netgear told me i needed to speak to telstra advanced tech as the firmware is done in house at telstra. They told me nothing could be done as it is updated OTA, i queried the provision on the units homepage & was told they dont know...
        My unit is with telstra for evaluation at the moment, willl be interesting to see what they say
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi td1812090,
    Sorry to hear about your experience since doing upgrading to the latest firmware.  I would like to investigate this further.  Can you please send your details to [email protected]
    Name
    Contact Number
    IMEI
    Software Version
    Test Location
    Speedtest.net Result (Use Telstra Server)
    Your assistance to send me the above so we can further investigate would be appreciated.  Looking forward to hearing back from you soon.
    Kind Regards,
    ArodiD
